weird issue with battery
I believe there is something wrong with the Logic Board - it will work fine as long as there is no battery connected!
If you connect a battery (I have tried a dead one and a brand new one that I just bought and tested in another mac) and it will work for about 30 minutes, before just shutting off and not turning back on. Unplug the battery, wait a few hours and it will work again without a battery, on the charger only.
Is there something wrong i can check with the circuits that control the battery charging system?
edit: after the 2 hour waiting period, after it shuts down, it will work normally with the battery for another 30mins or so,and will repeat those stages.
Also during the 2 hours it will not work after shutting down, the battery indicator doesn't show a battery installed, and the mag-safe indicator is a faint green, turning bright green after the 2 hours, when it is able to turn on again.
3 Comments
any other suggestions are welcome!!!
by brad
after the last shutdown an error was reported, called a sleep wake failure. i have reset the smc, and installed coconut, which reports the batter to be working.
by brad
Can you post an image of coconut so we can see.
by Dan
