Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone 5G Showing that it is charging, but NOT
Hello
I have an iphone repair business, but have come across a problem that I have not seen before.
I have an iPhone 5G which displays the lightening symbol when plugged into the mains, but the battery will not charge.
I have tried replacing both the charge flex and the battery, but the phone appears to be showing the same symptoms.
Would anyone have any ideas? I am guessing that it might well be a board issue now
Many thanks in advance
John
1 Comment
I think you answered your own question, LOL. I was going to suggest a board issue, but you beat me to it.
by
Add a comment
Chosen Solution
John, the way to proceed would be a new battery first (which you already did), if that does not work replace the lightning connector. Should this fail as well, you will have to take a close look at your logic board. It is possible that you are having problems with the charging circuit. You may have problems with the USB IC protector or the charging IC. Take a look at those components and check for missing or burned components. To repair them you would have to reflow the BGA IC or even replace it with a reball. This is intricate repair and will require the right tools and the right skills. If you have not done that, you may want to leave it for a professional to do. So go with the easy stuff first.Hope this helps, good luck.
Score 4
1 Comment:
Hello oldturkey thanks for your post and advice. I have tried both battery and lightening connector with no luck. Looks like it will be a board repair. I don't suppose you know of anyone in the UK that completes board level repairs do you?
by
Add a comment
Unfortunately In iphone 5G you can't replace the charge IC, trying to do that will damage the processor and then it's the end.
Add a comment
i phone 5g no charging symbol
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,021
