Nintendo handheld device released February 2011, identified by model number CTR-001.
286 Questions View all
Nintendo 3DS Wont Charge But power's on with carger pluged in.
I bought a Nintendo 3DS on eBay, already fixed software issues.
But it wont charge so i bought a new battery. When I changed the battery I found a T righten on the back near the battery place.
I've put the Nintendo with the new battery back together but it still wont charge.
The console as almost no usage damage at all.
What can I do to fix this problem?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Have you checked the charge port? I would say about 80% of these that I get have bad charge ports. If it's not broken then inspect it carefully to see if it needs re soldered (it probably does). If it looks good then I usually pry up the pins on the charge port where they meet the charger. I have a sharp straight pick for this that can get them.
I hope this helps!
Score 1
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 542
