Where Is the clutch plate located exactly?
I am trying to replace the clutch on my 2004 mazda 3. I have everything off that needs to be off, but before i open the transmission case i would like to know where the clutch plate is exactly. Which segment of the case do i need to open so i can take it out the easiest?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
gary, see if the image will help you out. Since you said you already have "everything off that needs to be off," I skipped that part:-)
1 Clutch release cylinder
2 Manual transaxle
3 Clutch release collar
4 Boot
5 Clutch release fork
6 Clutch cover
7 Clutch disc
8 Pilot bearing
9 Flywheel
Hope this helps, good luck
Score 1
Comments:
Thank you this helped a lot!
by
Add a comment
Add your answer
gary will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 40
All Time: 1,185
