Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3310 Questions View all
iPhone5 won't restore (error 2001) after screen+battery replacement.
Hello I got a screen replacement for iPhone 5. After I connected the screen I got a white line across it. I read it is due to battery getting disconnected so I reconnected the battery. Got even more white lines.
After reconnecting battery / screen several times I finally got the iPhone to boot without white lines.
Except this time it was a boot loop.
I tried restoring it via iTunes, but no luck.
The iPhone will also not start without USB.
iTunes gives error 2001.
iPhone is not jailbroken.
Score 1
Add a comment
Most Helpful Answer
I'm going to guess pry damage behind SIM tray on motherboard---but mostly because I fixed nine phones with that problem today :)
If a component called U3 is damaged the home and power button will not work and phone will boot to recovery mode. Fix = replace U3
Score 2
Comments:
And what is the cost of replacing a U3 please?
by
Or just try a different battery. The connection between the battery and motherboard may not be secure.
by
Add a comment
battery is not giving proper power in logic board
so only change the battery and solve the problem
Score 1
Add a comment
Try this www.support.apple.com/en-us/TS3694.
Score -1
Add a comment
Add your answer
zzzbog will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
All Time: 8,786
