Is alcohol the best solution?
If I have a water damaged alcohol the best solution for a quick fix or should I just take it in to be fixed?
Sadly, there is no easy fix after you get your device wet with anything.
Time and heat are both big factors after you get your device wet. As quickly as you can shake out as much water as possible place it into a refrigerator to keep it cool (don't freeze it!). If you can place it into a bag of Rice to help pull the moisture out.
If you have the needed tools to open the device do so and disconnect the battery and try to remove as much water you see until you can get it to someone who can go deeper. Just be careful here as you don't want to damage anything.
Depending on what it was you may need to address chemical reactive issues as well. As an example if you had drop your phone into a a stream or a lake how clean the water is also can effect what you need to neutralize. Also other spills like a soda have sugars and acids which both need to be removed besides the water.
I prefer to start the cleaning process with distilled water as it can address the chemical reaction issues and can remove any sugars. I use a good grade of Isopropyl alcohol (85% or better) to address the oils that maybe present and leverage the ability of alcohol as a dryer to help remove the remaining distilled water.
You should get the wet phone to a shop as soon as possible that is set up to deal with that the right way Rice is a joke don't use heat either, if it was salt water and you wont be able to get the phone to a shop within 2 days than submerge the entire phone in a glass of alcohol and leave it there untill you bring it to a shop, make sure the shop has a sonic cleaning device , good luck
As I stated there just isn't an easy fix here. Full submersion of the device into Alcohol is not a good idea as you will ruin the screen. While I agree Rice has its limits (which is why I put it at the end of first things) it does help. Opening up and cleaning things up as soon as possible is best, but that isn't always practical.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 142
1 Comment
It's hard to beat a couple of good dry martinis for a quick fix.
by mayer
