The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
79 Questions View all
Heater core not good. Can I still drive it?
So my heater core is no good. I can hear the fluid and when I use the heat the windshield fogs up with an oily substance. But no leaking inside of vehicle nor any leaks anywhere. Can I still drive my car if I just don't use the heat and always keep the air to cold so I bypass the heater core. Can I still drive it?
Add a comment
Chosen Solution
ronny muller, yes you can, but remember that you are losing antifreeze somewhere. So make sure that you check it often and that you do replace the heater core eventually. Or you can connect the supply and return hose together bypassing the heater core totally. Hope this helps, good luck.
Add a comment
I have an 2011 equinox, same problem like this quy. Bad heater core. Can i drive it without messing up something else? And is it normal for my car to want to stall at a stop light?
Add a comment
Add your answer
ronny muller will be eternally grateful.
Past 24 Hours: 18
Past 7 Days: 97
Past 30 Days: 453
All Time: 3,812
