Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3313 Questions View all
Black screen & beeps after battery replacement
Hi everyone!
I've searched around the web and i can't seem to find an answer.
The other day i replaced my iPhone's battery, and ever since the screen wouldn't turn on and when plugged in it would just beep every few seconds or so, no apple logo, nothing. Just a black screen, with no power.
When plugged in, vibrates as if it were turning on, and then the beeping begins.
I thought something might be disconnected but i checked the screen connectors and the battery connector and everything seems fine.
Any ideas?
Thanks everyone.
Score 3
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
Repeated bonging noise is a damaged display seen it many many times you might have damaged the cables without even knowing .. A new display will fix this
Score 3
Add a comment
Same happended to me, let me tell you why it happened first, you did not unpluged the screen in your phone, you replace the battery without removing the screen. EVERYONE IF YOU GONNA REPLACE THE BATTERY PLEASE REMOVE YOUR SCREEN. I replaced the screen as suggested and now the phone is working perfectly.
Add a comment
I have the same problem too. Beeping without apple logo, blank screen.
So did u solve the problem ? When I replace the battery I do remove the Screen.
It is need to replace a new screen will do ? Any website can buy the screen ?
Add a comment
I solved it.
Replacing the battery WITHOUT disconnecting the screen connectors busted the screen. So i inevitably had to replace the screen as well.
Add a comment
Add your answer
Miguel Alonso will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 4,013
