Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
136 Questions View all
it is posible install a mSata in iMac BASE 2.7 I5 EMC 2544?
I would like to install a mSata to my iMac because is very slow with the Seagate 1TB 5400rpm
My answers is if i can install a msata ssd on the motherboard or,this iMac haven't got slot on the motherboard as iMac model with Fusion drive?
Thanks
Add a comment
1 Answer
Chosen Solution
It's a lot of work to install a M.2 blade SSD Apple designed the system to support. It also turns out Apple is the only supplier of the needed SSD that will work in your system.
With the said, you could swap out your current HD for a SSD but you'll run into an issue with the internal HD thermal sensor the HD has and the SSD does not have. OWC makes a special cable which you could use to make it work. But given the added costs and the limits of storage doing a straight SSD I would recommend going with a SSHD instead. Seagate makes one that will work in your system.
That way you're getting the best value and performance. Or, sell your current system and get one with a fusion drive setup
Score 2
Add a comment
Add your answer
Appengineer L will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 428
