Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
814 Questions View all
New Battery and Hardrive, But iPod Shows No Sign of Power.
My iPod has been out of service since late october'08. at first, the light would flicker on and off of a blank screen, later stating that there was a problem and shut off completley. in the beggining, i thought it was a battery issue,so i replaced it with a new one. the problem still persisted and i was confused as to what was wrong. after playing around with it and plugging it into the computer with no signs of it being connected it soon showed the dreaded sad faced icon. back then, i had no clue what that meant and continued to force it into disk mode.a few weeks later, it shuts off completley and never comes on again. now, during this period of time, i get careless with it and drop it a few times thinking it couldnt make it any worse. after lots of searches on the net, i discover that the problem was with the hardrive. finnally, a year later (December '09) i get a hardrive for it and install it and everything, hoping that it would finnaly work.
it doesn't. not any movement from the hardrive when i plug it up to charge. i sort of forgot about it after a while, after initially being ticked that it didn't work.
so, i'm asking is there a problem with the logic board because of the careless drops or lack of power for so long? do i need A new one?
Any feedback Is Apriciated!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
It sounds like it is most likely to be the logic board, on the logic board either side of the dock connector there are block shaped transistors(?) when dropped repeatedly sometimes these can break off causing the logic to behave strangely or go completely dead.
Add a comment
Add your answer
Dalyss will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,524
