Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3233 Questions View all
Bottom of iPhone doesn't work after screen replacement?
So I replaced the LCD screen and when I was done and tested a few things, I found:
-audio speakers don't let out sound
-iPhone doesn't charge when plugged in and iTunes doesn't detect it
-the home button doesn't work
I realized that all the problems were located at the bottom of the iPhone. Is there any way I can fix these problems?
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
1 Answer
Chosen Solution
All these problems relate to the dock connecter not being plugged in correctly.
Open up when and reseed dock connecter as it sounds as if it's not plugged in
Score 2
Comments:
It worked!!!! Now everything works perfectly!!! Thank you soooooo much!! :D
by
Your welcome
by
Add a comment
Add your answer
henry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 256
