The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1550 Questions View all
What am I doing wrong!? (Display problems)
I have been repairing phones for years, I own a cellphone store and fix multiple 5c's a day. However, it seems as though about 50% of them have display problems after i replace the lcd digitizer. At first I blamed it on bad parts or the phone being damaged beyond repair but I realize now the problem must lie with me. Over and over again im seeing blocks and weird lines run across the screen, purple fade outs, discoloration, etc. Always the lcd. If some one knows what im doing wrong please help! Thanks
Add a comment
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Answer
Chosen Solution
In the iPhone 5 , 5c and 5s you need to take care of the lcd connector it's not like the iPhone 4 were it can bend you have to put your finger on the metal peice at the start of the lcd cable then gently loop the cable over the finger...
I always test the screen before I start adding the camera and home button..
When you install the new screen plug in the connectors then leave it at 90degrees and turn on inspect the screen for damage or bad lcd if not then install parts and if screen goes bad after installing then you no it's you fault..
Score 1
Comments:
THANK YOU SO MUCH. I followed your instructions and several that i had not functioning properly are now working. You have saved me from one of the worst problems I've had in years. You're great!!
by
Glad to help just take your time installing and never rush 10 minutes longer to install a screen is better than breaking it
by
Add a comment
Add your answer
Austin Harris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 697
