frigidaire works ok, bout only fills with cold water
model number ffle1011mw2 frigidaire stackable washer and dryer. All settings work ok; fills with water after selecting either hot or cold, but water in tub is always cold. All cycles run to completion. Checked water hoses: not kinked, hot water getting to washer ok.
5 Comments
I have the same problem and to top it off my rinses are coming out hot!!! You never want to rinse clothes in hot water because they wrinkle. My husband changed the hoses to make them opposite and it didn't make any difference.
by Sara Dunn
@saradunn
What is the model number of the washer/dryer combo unit?
by jayeff
@jayeff
The model number is FLCE752CAW4
purchased a July 2023
by Sara Dunn
@saradunn
Given that you only got it in July '23, get if repaired under warranty.
Seems like the temp control is not working and it should always rinse in cold water only.
by jayeff
I’m considering hooking both hot and cold water supply to a Y fitting connected to my hot water outlet. I live with a hot water rinse. Better than cold water wash all the time. Especially for towels, bedding and under clothes.
Al - Vancouver BV
by Al Siddons
