The Asus F6A-X2 is a member of the F6 series of notebooks and runs on Windows Vista.
2 Questions View all
Why is there no sound coming from my laptop?
When I bought my laptop, it had wonderful sound, but after using it for a while, the sound stopped working. What happened, and how do I fix it?
Score 89
26 Comments
I had this problem and went thru all the answers online... then I went into control panel, sounds... and found the sound was turned off for Chrome... turned it back on and solved the problem... I think an update turned it off because it had been working properly before I updated on Windows 8
by
thanks vergo . it worked for me
by
for driver and support visit asus https://goo.gl/a5YmEg and see if that helps you to fix the sound
by
thinks it was very helpful . i almost fixed the sound issue but its little low as it was before i think i have to some adjustment in sound settings
by
Are you talking about Chrome settings or Control Panel? My Control Panel thinks the sound is fine, but I hear nothing. I find no sound settings in Chrome. Volume is up, everything on. Hear nothing. I think Asus is a problem...
by
Show 21 more comments
Add a comment
Chosen Solution
If sound has stopped working there are few tips you can try.
At first, Make sure that Audio Devices are enabled on your Windows 8 PC. You will have to go through volume icon beside notification area on taskbar and right click on the icon. Further Click on Playback Devices and enable through properties menu box.
If issue is fixed then it is OK, otherwise Update Audio Device Drivers.
If you have set auto install for Windows update on your windows 8 PC the drivers will be updated automatically. After setting never check for updates your Windows couldn't install the updates coming from Microsoft. In this situation go to Device manager and update the Device driver manually thanks
Score 18
9 Comments:
i dont have playback devices i dont know why maybe the internal speakers are broken :,(
by
it started with crackling and the i tried to fix it but it got worse then now it has no sound whatsoever
by
Just uninstall your audio driver and install it again.
by
What about windows 10???
by
It's a very similar procedure.
by
Show 4 more comments
Add a comment
update the sound driver that will help before changing the motherboard . remove all older version of software and download the sound driver and see if this works nd get the problem fixed
Score 10
3 Comments:
thanks a ton.. it was very helpful and i got it fixed
by
great it works .. thanks
by
i had to uninstall the driver and load it again . I removed many programs also . I guess driver was corrupted . thanks a lot
by
Add a comment
Here’re 5 fixes that have helped other users resolve the ASUS laptop sound not working in Windows 10, 8.1, and 7 issues. Just work your way down the list until the problem is resolved.
Troubleshoot hardware issues
Before we make any changes, we might have to troubleshoot hardware issues. To do so:
  • Make sure to check your speaker and headphone connections for loose cables or the wrong jack.
  • Try connecting your speaker or headphone device to a different port and see if this fixes the problem.
Make sure the volume is audible
Sometimes you can’t hear sound from your speakers simply because the volume is muted or set too low.
  • Click the sound icon on the lower-right of your screen, then move the volume slider all the way to at least halfway up.
  • Test if you can hear any sound from your ASUS laptop.
Set default audio devices
Ideally, when a new audio device is inserted, Windows will automatically set it as the default audio playback device. But that’s not always the case and sometimes we’ll have to set default devices manually.
  • Right-click on the sound icon on the lower-right of your computer screen, then click Sounds.
  • In the Playback tab, click on the audio device you wish to play, then click Set Default. Click OK. If the audio device you’re to play doesn’t show up in the device list and right-click on the empty space and tick Show Disabled Devices. Then right-click on the device once it appears and clicks Enable before you do step 2).
  • Check to see if your ASUS no sound problem has been fixed.
Disable audio enhancements
Audio enhancements, as the name suggests, are features that allow for the highest sound fidelity from your hardware. But depending on your configuration, they can also interfere with your system and trigger sound problems. So we should disable audio enhancements to see if it fixes the no sound on the laptop problem.
  • In the Playback tab, right-click on your default audio device and click Properties.
  • Click the Enhancements tab, then tick the box for Disable all enhancements and click OK.
  • Test your audio device and see if no sound issue is resolved.
Update your audio driver
This problem may occur if you are using the wrong audio 'driver or it’s out of date. So you should update your audio 'driver to see if it fixes your problem. If you don’t have the time, patience, or skills to update the driver manually, you can do it automatically from the Asus driver support page.
Score 10
2 Comments:
Assuming that you tried putting on Headphones or External Speaker and still doesn't work, Try going to Windows Services then search for Windows Audio, Right Click it then Select "Restart", Otherwise go to Speaker Properties then Choose Enhancments then Tick Disable all Enhancments. Finally Try Disabling your Sound Driver through Device Manager then Enable it..
by
It can be something to do with your sound drivers or the sound controllers.
Why don't you try uninstalling those drivers and reinstalling and also check the audio settings and play with the devices selected in there.
by
Add a comment
Kevin Yang, check in your device manager and verify the status of your audio device. Reinstall your driver and see what you get then. Also, attach some external speakers and see if you still have sound.
Score 7
2 Comments:
How do i do that?
by
SOLVED - I Fixed the problem, Go to Upper-Right Corner where you see those 3-Little-Dots, Click and Scroll down to "MORE TOOLS", Then Click EXTENSIONS section in pop-up next to it. Remove any "Audio Boosters" that you personally added AFTER you purchased it. Click on the Clock on the Lower-Right Hand Corner and LOWER your Sound, Then RELOAD Computer by Turning off/on your computer and the Sound will come back to Normal - Yay! :) :) :)
by
Add a comment
If you do not hear sound coming from the laptop, first check if the sound is muted or set to low on the laptop and application. If this is not the case, your speakers may be blown out. Check the troubleshooting page for more details.
Score 1
1 Comment:
by
Add a comment
I had this problem and went thru all the answers online... then I went into control panel, sounds... and found the sound was turned off for Chrome... turned it back on and solved the problem... I think an update turned it off because it had been working properly before I updated on Windows 8 .
Thanks,
Add a comment
Add your answer
Kevin Yang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 295,496
