Audio Cable is Broken!
My audio cable is not working. What should I do in order to fix the cable?
Clay Jacobs, you could replace the 3.5mm audio jacks on either side, if you know how to solder. The soldering is identical to this repair . Easiest would be to get a replacement cable, should be about ~$5-$10. Hope this helps, good luck.
It depends on what problem you are having with the audio cable.
You can check the following troubleshooting guide (Troubleshooting Beats Studio First Generation) to help diagnose the problem.
If all else fails, the guide recommended by oldturkey03 should be great for soldering on new jacks. If the in-line buttons are the problem, it would probably be easier to buy a new cable.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 685
1 Comment
Where is is broken? At the ends by the connector?
by oldturkey03
