Won't connect to Xbox live?!
My Xbox won't connect to Xbox live even when I plug in a Ethernet cable. The top (USB Port) works, but the bottom (Internet port) doesn't work. Help!?
There are a couple things that could be causing this problem. First check your ethernet cable, it may just be defective or the wrong type of cable (eg: a crossover cable). Try using it on another device or just using a different cable to verify that it isn't the problem. If the ethernet cable is okay and the console still won't connect, look at the ethernet port on the console. Check for bent contacts or other visible damage. If the connector looks okay, please tell me a little more about the console and when you started having the issue so I can try and figure out the source of it. Good luck!
Well it fell on the floor, not that big of a drop but everything worked. When I wanted to connect to Xbox live, I got that problem. I tried the Ethernet cable on something else and it worked. Guess the Ethernet cable isn't the problem.
U dropped your xbox and ur mad it wont connectto xbox live? U should be glad it even works
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 427
