Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
534 Questions View all
How can the fans be disassembled without damage?
I have a fan that's very audibly grumbling while at idle speeds. I've opened the case and cleaned the fan blades and casings, with no result. I suspect there's dust/dirt in the actual bearings inside of the fan.
I've attempted to gently (but very forcefully) pry the fan piece with the blades away from its axle, to no avail. I fear that using more force would break it, but I can't tell how it's connected to know for sure.
I'd really like to fix this problem without dropping $50 on a replacement fan, if all I need is a cleaning.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
Sadly, these fan units are not really designed to be taken apart. While its fun to do on a junker, if you want to reuse it it just won't do. Best to replace.
Score 2
Add a comment
take some compressed air and some elektronic cleaner.
wd40 could also work. cheaper and easier is to buy a new fan.
Comments:
Fairly confident on how to clean it -- it's how to get the pieces of the fan to physically separate that I'm having a hard time with :). I feel like if I pry against the rotor any harder, something's going to snap.
by
First I won't use any oil (including WD40) as it will attract dust which will clog the bearing and the blades.
by
Add a comment
Add your answer
Tom Frost will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 60
