Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Questions View all
Logic Board or Power Supply or Hard disk Failure?
Hi all,
My iMac EMC 2210 is unable to boot at all.
Trying to find out whether it's a logic board or power supply failure.
I have just replaced my hard disk approximately 1 year ago but I am not writing it off the equation.
Pressed the power button but has no chime nor visual.
I could hear the fan sound (but couldn't be sure if it's the fan or hard disk).
Any guidance is greatly appreciated.
Score -1
4 Comments
Update / Additional Info
I left the iMac off for a couple of hours and managed to boot it for now.
Is it overheating ?
by
Can you give us the last three digits of your systems serial number so we can correctly identify your system.
by
Hi Dan,
Thanks for the prompt reply.
Last 3 digit of serial is ZE3
Model 1224 , EMC 2210.
Didn't manage to use Temperature gauge pro due to my comp is officially dead once more.
by
Apple iMac "Core 2 Duo" 2.66 20-Inch (Early 2008) Specs
Identifiers: Early 2008 - MB324LL/A - iMac8,1 - A1224 - 2210
by
Add a comment
1 Answer
Chosen Solution
To check if the system is over heating you'll need to install an app which can read the fan & temp sensors in your system. Give this app a try: Temperature Gauge Pro There are others but I have found this one to be one of the best. Let us know what you find after running it.
Score 1
10 Comments:
Hi Dan, Thanks for the prompt reply. Last 3 digit of serial is ZE3 Model 1224 , EMC 2210. Didn't manage to use Temperature gauge pro due to my comp is officially dead once more.
Chee Yong Koo, 11 hours ago
Apple iMac "Core 2 Duo" 2.66 20-Inch (Early 2008) Specs Identifiers: Early 2008 - MB324LL/A - iMac8,1 - A1224 - 2210
by
Starting to should like your power supply has issues. At this point I think you'll need to open the system up to inspect things. Are you up to that? Review the IFIXIT guides and setup your work area if you haven't already.
by
Yes, I am ready to open up. Any guide is appreciated.
by
Follow this link: iMac 20" repair guides
by
Thanks for the guide.
I have no issues replacing the hardware as required but the main issue here is that I couldn't rectify if it is a Power Supply failure or Logic Board.
Any ideas?
by
Show 5 more comments
Add a comment
Add your answer
Chee Yong Koo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 272
