Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2940 Questions View all
Possibly sleep/wake button problem. (Black screen)
Hi!
I have replaced the screen on a friends iPhone 4s.
The screen works fine at first when I turn it on, but after the screen goes black by itself or I push the sleep/wake button to make the phone sleep, it wont come back on.
(screen comes back on if I wait a while, but only once, then I have to wait some more)
I can see a little back light going on and of as I push the sleep/wake button, but nothing more.
I can turn it of without seeing and back on again and then it works fine until I push sleep/wake button or it times out and sleeps automatically.
Anyone had this?
Thank you!
Add a comment
Chosen Solution
Sounds like a connection problem or faulty screen..
Open back up and make sure the connections are seeded correctly if so and the screen is doing the same then I would try the old screen and see if it happens to that..
Comments:
Pretty sure its not connection problems. Why would it work fine after a restart evry time? :)
by
Just don't rule it out that's all I'm saying
by
I understand, thank's! :-)
by
No probs hope u get it sorted update us if you get it fixed thanks
by
Add a comment
Mine is doing this after being dropped, have tried restoring from a backup, and restoring as a new phone. I'm about to open it and check connections, will update with results.
Comments:
Yes! Opening it up and re-seating connections has done the trick. Now to duct-tape the phone to my body so I don't drop it again.
by
Add a comment
Add your answer
Fredrik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 408
