Toshiba Satellite M55-S1001 (Celeron M 1.6 GHz, 256 MB RAM, 60 GB HDD)
2 Questions View all
Why are these HDD connectors not the same?
Here is the computer connector and the hard drive. Why are they different?
Score -1
Add a comment
1 Answer
Chosen Solution
Your Toshiba unit uses a PATA interface for it's hard drive. Sadly, the drive you have here is a SATA based hard drive which is a newer standard.
These drives are not interchangeable as you have discovered these use very different connectors.
Score 3
1 Comment:
Thank you!!!
by
Add a comment
Add your answer
Matthew Halbert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 129
