Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1284 Questions View all
boots up to black screen / Shut Down message often if running
15" PowerBook. 1.76 GHz, Most times it boots to black screen. Before this mostly dead season it would boot up after a few tries. If running, has kernal panics often if not being used. Hardly ever wakes up from sleep correctly.
thanks, - Bill
results@latocki.com
Add a comment
1 Answer
Chosen Solution
Since you mention kernel panics I would first reseat the ram. Make sure the socket is clean and the memory snaps solidly in place. If that does not correct your problem try booting into your system disk and go to utilities/disk repair. Run disk repair until it reports no trouble found. Good luck. Ralph
http://docs.info.apple.com/article.html?...
Score 1
Comments:
agreed +
by
Add a comment
Add your answer
Bill Latocki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 352
