Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
87 Questions View all
Engine cutting off when brake/clutch pedal released
I have a Murray riding mower model 46503X8.
I depress the clutch brake pedal to start the engine. The engine starts easily and runs when the brake/clutch switch is depressed.
If I release the brake/clutch switch the engine shuts down. I replaced the brake /clutch switch and the pto switch, but the problem did not go away.
I did the following test. With the engine running and the brake /clutch switch depress, I engaged the cutting blades (pto switch) and the engine shuts down.
I have an electrical diagram but need help to solve this problem.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Further checks revealed that the seat switch was defective. Once I replaced this, I was running and cutting the grass.
Score 1
Comments:
I had the same problem with the brake pedal but my seat safety switch was disabled before the problem arised.... and everything worked fine ???
by
Add a comment
Add your answer
Harry will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 53
Past 30 Days: 213
All Time: 6,132
