Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 Questions View all
How to fix a broken iPad mini retina screen
I have a broken iPad mini retina screen. How could that be repaired and what cost. Apple Store cost is 249.
Score 1
Add a comment
Most Helpful Answer
I'm not quite sure exactly what you mean---
If you mean you have an iPad mini retina version device that currently has a cracked touchscreen, then you can either order a screen assembly and follow a guide to try a DIY screen replacement, or send it out for glass screen replacement service.
If you mean how do you repair a broken LCD itself--that is generally not possible, folks just order a new retina LCD screen as a replacement part.
jessa
Score 1
Add a comment
It's more difficult than full size iPads. A lot of tape needs to be transferred and the LCD needs to be carefully separated. Any DIY kit should be sure to include a digitizer that does not require soldering.
Score 1
Add a comment
Add your answer
Wes Pitts will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,524
