Repair manuals and support for 4-wheeled passenger and cargo vehicles.
6688 Questions View all
My 1999 Isuzu Rodeo suddenly died and won't run.
I have a 1999 Isuzu Rodeo, 6 cylender with automatic transmission. It has over 240,000 miles on it and for the most part I have had no trouble to speak of in the last 6 years. I was surprised when while driving at about 45 MPH the car just shut off. I have gas, the fuel pump is working, i have fuel pressure on the fuel rail, the coil packs are firing and I replaced the spark plugs yesterday.The vehicle tries to start (the engine "Turns Over") but won't start and run.
I Need Help!!
Score 1
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Most Helpful Answer
Hi there. Check the timing belt. You usually have to replace the timing belt every 120,000 miles. If the timing belt has snapped, the engine will not turn over. Hope this helps.
Score 1
Add a comment
he tenido este mismo problema y descubri que el mecanismo en la llave de ignition se habre un contacto entre
los cables debido a la temperatura interior y vuelve normal cuando enfria ,
Add a comment
Add your answer
Frank will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,913
