Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3252 Questions View all
iPhone not charging battery or is seing battery as dead
After replacing the digitizer and reassembly (NB the iphone was sitting unused for a whole month) i noticed my iphone battery life would sometime go up or down while charging until it was completely dead, so i let it sit and charge for about a half a day it only charged to 40% and wouldn`t charge any further it just kept draining so i went ahead and took out ye ole multimeter and tested, the voltage of the battery connector is 1.19 volts while the iphone is plugged in without the battery (im a little concerned as to that being the voltage that should be provided) and the battery itself is spitting of around 2.98- 3 volts that`s quite good i guess if its supposed to be 3.7 fully charged. I tested 3 parts (that i saw on another post, the 2 fuses and that chip looking diode i think) where the dock connector connects to the logic board they seem fine. Now i`m wondering what could be the problem is it the battery that has gone bad, i got a bad dock connector, bad IC, bad charger cable or is there something causing the iphone to think the battery is dead when it has life?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
SLG Shark6, I would start off with a new battery. Anything else can be misleading. Once you have a new battery you have a known-good starting point for further trouble shooting.
Comments:
I am in the process of getting a new cord and battery, will update as soon as i get them
by
I got a new battery from here did the trick, charges perfectly i guess the 1.2 volts reading i got was just the reduced voltage from the iphone trying to turn itself on when it doesn't have the battery in.
by
Add a comment
Add your answer
SLG Shark6 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 123
