2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
304 Questions View all
What Does Each Fan Cool?
My computer has been greeting VERY VERY Hot lately, and the fans were not spinning at all, so i got a 3rd party app to control fans, I like this because I actually lowered the required temperature down from the standard Apple set. I would rather have a safe computer than a quiet one. But my question is, since the app gives me control of each fan separately and I can control the speed of each based on the temperature of 9 different parts of the computer, what components does each fan cool?
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
The fans cool the GPU, CPU, power supply, HD and logic board. The sensors are placed to monitor these areas along with the LED/LCD Optical Drive.… if a sensor fails the fans, by default, go into high speed mode.
Fans have finite lifetimes in run hours. running them when not required, or all the time will shorten that life. Manual control of fans IMnsHO is not a good idea or practice. you might have both fans fail at the same time, resulting in the cooking of vital components.
You could already have a failing fan or sensor (even new parts fail that's why there's a warranty)… run AHT 2 0r 3 times in succession (often with heat problems running it once does not stress the system enough to find failing components). A machine this age may still have warranty and a trip to an Apple store or Certified service center would be my first step… not the drastic action you are contemplating.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Add your answer
Jeffrey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 216
