Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
iPhone fried due to an external battry pack! ;(
I need the iPhone 3GS 16Gb part Number PMIC 338S768 ? from where can i get it ?
thx-A-Ton
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The only source that i found is this: http://mobpart.com/index.php?main_page=p...
Comments:
thx i know about them but the freight is like more than the orignal product !! any other solutions pls tell thx
by
The price for the fright from shenzen could not be that brutal - the problem is pretty simple - if you need it and they are the only dealer sellig it - well, it's a "do or die" thing.
the point is pretty simple: without this part is your phone most likely a brick - with this part it is a fully functioning iPhone. the differenc is huge ;-) but are you able to change this part on the iPhone? does the part have a supporting underfilling? and again: are you able to do that ? (with the proper tools and knowledge to solder anything on a logicboard where almost everything is "glued" and highly problematic to solder on (no big difference between infrared or hot air)
by
hmm you are right thx much appreciated
by
Add a comment
Add your answer
heet6 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,116
