The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Questions View all
Dryer won't start. No error codes. Replaced thermal fuse, door switch.
My dryer won't start. The red lights work and light inside work, so it has power. I replaced the thermal fuse and door switch. No luck. The panel lights work normally. After I select the dryer setting and start it, it beeps, but doesn't start. I don't here any noises after the beep, nor do I see the drum move. I do hear a click coming from the area of the PC board as it beeps. Also, the fan spins freely, so there doesn't appear to be anything obstructing it. The drum turns by hand. The belt is attached and in good working order. I checked the PC board. No obvious signs of being burnt. I suspect the motor is bad, but don't want to replace it if that isn't the problem. Is there way to further diagnose the dryer or the motor specifically? Thank you.
Score 6
5 Comments
i have the same problem; i ran an extension cord to another outlet and still the same problem. any other advise? Kevin - did you ever fix the dryer? was it the motor?
by
I have the same problem but only 3 of my panel lights work. Sometimes if I hold the start button long enough I can get it to start, but not any more. Outlet works, light comes on inside and beeps when I try to start it on those 3 settings but nothing happens. Is it the control panel?!
by
I had this exact issue, control panel worked fine, I would push start button, motor would not start to spin drum, and all I heard was a relay switch click twice around the control panel. FIX FOR ME: I had the LG repair technician stop by, he removed the front panel assembly (just remove front screws (door must be open to access them), then he removed the drum belt and drum to access the main motor that spins the drum (located on lower left when facing the front of dryer), and noticed one of the wires that powers the motor had fallen off. Once we put a new connector on the wire and re-attached it, the problem was solved. Hope this helps everyone. -DD
by
My daughter bought a brand new DV45H7000EW/A2 Samsung Dryer at Sears scratch and dent store. There was no manual and she was foolishly impatient, so she attached the pigtail to the back and guessed at which wire went where. BAD IDEA! She connected them wrong, pushed the button to turn it on and the dryer made a noise for a sec, and then went dead. Absolutely nothing lights up and no indication it has power at all.
I did check the breaker switches and found them blown, so I reset them with no luck!
So then, I guessed that the control board had gotten burnt out and replaced it with an identical part I bought on eBay for $25. No change at all and I don't know whether the old board is good or bad.
So now I'm thinking I need to replace the thermal fuse - DC47-00016A. Just ordered the part and it should arrive in 4 days on February 13, 2018.
Wish me luck!
by
Steve, Samsung makes great phones, but AWFUL appliances. And they charge a huge amount to come out. However, they will help you trouble shoot by phone.
by
Add a comment
Chosen Solution
Use a multimeter to test the wall plug. You should have 2 polls giving 110-120 volts each and a ground. It sounds like you may only have one side hot and the other not.
UPDATE 1/15/16
\Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown out. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Cause 2
Start Switch
To determine if the start switch is defective, attempt to start the dryer. If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a multimeter to test the start switch for continuity. If the switch does not have continuity, replace it.
Cause 3
Door Switch
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the “click.” If the door switch makes a clicking sound, it is probably not defective. If you don’t hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Score 4
2 Comments:
I replaced the thermal fuse on my dryer, it started briefly but now it doesn't. I used my multimeter to test the fuse but it did not have power neither did the fuse next to it on the blower. I tested another power source fuse and it registered power. What do I need to do here to find the lost power source?
by
Look for a break in the heating coils that may be shorting out and blowing the fuses.
by
Add a comment
Ok think I found it. My dryer was doing the same. Had power, and when you hit start you would just hear clicks from the circuit board. Long story short check the wires going into motor. Mine was a blue wire that had burned its connector off. Good luck.
Score 4
2 Comments:
How did you fix the burn wire?
by
Had the exact same issue. After a lot of frustration testing parts I saw this and bingo! Blue wire with burned off connector.
by
Add a comment
Check on the inside surface of the front lower panel, and hopefully you will find a diagnostic/tech sheet that will allow troubleshooting of the control board (front panel board).
If a microswitch had gone bad, the computer will not allow any startup at all (appears dead at panel).
The diagnostic is easy with a regular ohmmeter. but you do need to completely remove the board.
If board is bad, replace ($300+), or if its just a microswitch.. remove and resolder a new one ( $0.50).
Good luck !
(btw, I posted why I think this is a design fault of the he3/4 line , and a workaround ,in one of my other posts)
Score 2
Add a comment
I have kind of the same problem. The dryer is hard to start. I have to hit the start and then the off button several times before it will start. Each time I press the start button there is a click and the drum will jerk a little. Sometimes it will start on the first press other time I have to press start - off 10 times before it will start. One it starts everything seems to work ok. I have tested all of the settings and it does this in all of them. This is a maytag 9700 series
1 Comment:
Hi Cygnus 008, I have the 9700 series- hard to start but don't hear any clicking. What usually gets her going again is unplugging, waiting and replugging with one push to the Start button. I have noticed leaning on the left front corner has got her to start! with out having to push the Start button a second time. Judging by your posted date, I suspect you got her working....any tips of what the problem was or what my machine's illness might be?? THank you!
by
Add a comment
I know this is an old post, but wanted to add to this thread for others. I just had to fix my Maytag with same symptoms. I wasted a bunch of time removing panels and checking/replacing switches and fuses. Go straight to the main board. Took all of 5 minutes to remove and I could clearly see from the back of the board that it was toast and scored the metal behind it. Wasn’t cheap, but found locally for around $225 likely can find cheaper online if willing to wait. My Wife was not as I had already wasted 4+ days checking the other items.
Again, check the main board first thing before wasting time dismantling several parts to get to the various thermistors/thermal fuse(s)/switches/etc..
Add a comment
My Samsung wouldn’t start but if you manually rotated the drum to start it, it runs fine. The centrifical contact arm in the motor switch had the contact head burned off so there was no start circuit for motor… only run.
1 Comment:
I replaced the motor $75 on internet. Works fine now
by
Add a comment
Mine won't power on at all.. Anybody know what that might be?
Add a comment
I have been through the entire troubleshooting process on this particular problem also.
I can also confirm that the blue wire connection to the motor is the faulty component, none of the other parts were a problem, Even after spending a few hundred dollars replacing them unneededly.
All I did was clip off the burnt end of he wire and reattach it to the motor clamp.
Working perfectly now
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 40
Past 30 Days: 155
All Time: 91,760
