The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
602 Questions View all
Can't connect the display/digitizer connector back in.
Title is in the description. I tried every way and cant seem to fit it in. I tried with the old display and it fits perfect. Does anybody had this kind of problem?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
It's a defect flex from your new display. I've had this happen several times (original samsung screens) so it's deffinitely not an uncommon problem. Simply return it from the place you purchased it and ask for a new one.
A tip, which I always do now, before moving any thing over into the new screen always place in the motherboard and try to connect the flex cable first. Saves a lot of time in the long run!
Score 2
Add a comment
As you said, it must be the problem of the display, you can exchange the display you bought. Compare the pins on the connectors with old display to see if they are right.
Score 1
Add a comment
In my attempts to connect the display, I managed to mangle the connector, rendering it useless. I've seen YouTube videos showing how to replace the FPD board connector, but is there a way to replace the ribbon side?
Add a comment
Add your answer
Julien Kovacs will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 954
