Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Why my iPhone 4 is not booting after touch ic soldering?
This iphone had a problem with the touch screen.
The problem came from the motherboard, because with another screen, it still didn't work.
Since I already repaired an iphone 4s with a faulty touch ic, I thought changing the touch ic on this iphone 4 would fix it.
Problem is, I apparently overheated the motherboard and it does not start.
Here are 2 pictures of the overheated area.
Is there anything I can do to know what is damaged ?
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Most Helpful Answer
Pegston39, the images are not quite as clear, but it sure looks like you got plenty of heat and melted plenty of stuff. Looks to me like you are in for a new logic board. To evaluate all the damage, I suggest you remove all the EMI shields, wash your board with isopropyl alcohol and a soft brush. After that, add a few more high res images of your board to your original question.
Score 1
Add a comment
Add your answer
Pegston39 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 100
