Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
does battery replacement lose every thing on iPhone?
Is all data and apps and music lost during battery replacement?
Add a comment
Chosen Solution
The iPhone memory is non-volatile flash, which means that you won't lose data by disconnecting (or completely draining) the battery.
However, you should *still* do a full backup before attempting any repair or sending in a device for service. For non-jailbreak iPhones, the iTunes backup is very complete.
For jailbreak phones, install AppBackup from Cydia and follow its backup instructions, then backup using iTunes. If you need to restore, you'd have to re-jailbreak, install AppBackup, restore from iTunes, then restore your jailbreak apps using AppBackup's restore features.
Score 3
So should I JB forst and then backup my JB with AppBackup from Cydia and then send in for battery replacement?
Send in for battery replacement and then JB? I am in 10.3.3 now and need a battery rep. Thanks!!
Add a comment
AFAIK not.
Add a comment
I replaced the 3GS battery and lost nothing.
Add a comment
Add your answer
dickm will be eternally grateful.
Past 24 Hours: 93
Past 7 Days: 631
Past 30 Days: 2,552
All Time: 24,111
