Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
415 Questions View all
How to differentiate between a hardware Failure or a broken firmware?
Hi everyone,
How can I differentiate if my computer has a broken firmware or a hardware problem?
1. Not able to go into Safe mode
2. Not able to reset SMC
3. Not able to reset NVRAM
4. Have to press the power button a few times to start-up
Steps taken:
1. Clean installed Os X versions 10.7, 10.8, 10.9 the problem remains in all of them
2. checked file permissions and ALL OK except Safari permission (not getting repaired)
3. Disk verification: ALL OK
My Boot ROM version is MB71.0039.BOE
SMC version: 1.60f6
I am also not able to find the Apple's Boot ROM recovery CD from their website... :(
Any help or guidance will be very appreciated.
Thank you
Add a comment
1 Answer
Chosen Solution
Other than having Apple give you an estimate (and some more background information) I can only speculate but it sounds to me like a failed SMC chip. Help us help you. the more we know the more help we can be. More background (when this started, (e.g. after a fall, spill, any other pertinent information) .
If this answer is acceptable please remember to return and mark it.
Score 1
Thanks machead3 for the comment. I am using a Macbook 2009 slowly upgraded to Mavericks.
It started with my earlier problem described Why is the MacBook Keyboard not working after upgrade to 10.9.2?, I tried to downgrade Mac Mavericks with the USB installer created from downloaded copy of 10.9/8/7. All these installs did not seem to solve that problem (which I think is related to 10.9.2 update ruining my keyboard mapping), but after the reinstall the power button had to be pressed a few times before the mac booted. Thought I had somehow ruined the SMC firmware, or hardware. However yesterday I installed the cloned copy of my old Mavericks of CCC and the power button problem is solved. Which means that downgrading and/or, reinstallations had somehow corrupted firmware files. I need to find a way to reinstall the keyboard firmware to working again since I do not have my old 10.8 back-up I cannot find a way to reinstall/recover the firmware files.
Any suggestions?
I would go over to Apple Discussions for help. Your Apple ID will let you post/read discussions. As policy we do not generally answer software Questions - unless the answer is known by the person who first Answers the Question - and the Question is often removed as "not repair related". I see others have your problem. I don't know the Answer.
Thanks machead3... till now I was not sure if this was really a software or a hardware problem... or I wouldn't have posted... will keep this in mind next time...
A LOT of thanks for your pointer.. I was not using the right keywords perhaps... these are new links for me...
PS Though IF I do find the solution I will update the post..
Thanks -that will be helpful to others if the moderators decide to keep this active.
Add a comment
Add your answer
Alok will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 353
