2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Don't know whether the problem is with the screen or the cable
https://docs.google.com/file/d/0B6RkxkAm...
And when i hold the screen so hard
That is what i can see
And sometimes i can see the whole screen
It just depend how hard i'm holding it !
And from which side i'm holding it exactly
Score -1
2 Comments:
I can't see either of your links. I get this: You need permission
by
SALAM ALMAQABI, you will have to fix your links. We can not access your images. It might even be better if you attach those with your question. Use this guide Adding images to an existing question for that. Also, what are the last three digits of your computer serial number? That will help us to properly identify your computer.
by
Add a comment
1 Answer
Sounds like you might have either a damaged cable or a loose cable, if you feel comfortable, I would suggest opening up the device and checking your display cables.
3 Comments:
Are there 2 display cables?
Cause when i unplugged one of them nothing happened the screen still works
by
I just checked the cables
One of them for the camera and the other one for the screen
by
Do you think if i replace the screen and the cable it will work?
Or there might be a problem with graphic card?
by
Add a comment
Add your answer
SALAM ALMAQABI will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 101
