Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Changed screen on my iPhone 4, now it wont charge.
I changed a screen on a iphone 4. And now it wont charge. I have checked the flex cabel to make sure its properly fited, i even tried to change the dock connector. I have also tried with another battery. Any ideas? I am not feeling good about this, because i did this repair for a friend...
EDIT:
I have now tested the phone with a motherboard forom another iphone 4, and now it charges fine. So i guess its a problem with the motherboard? What should i do now... Any suggestions?
Score -1
Add a comment
Most Helpful Answer
Check all connections and clean it make sure that everything is not damaged or burned then unplug everything and put it all back together and put it on the charger maybe that can solve the issue. Hope this helps.
Score 1
Add a comment
It's possible you damaged componants on the board. Did u pry the battery off against the board?
12 Comments:
I pryed it up from the battery side. So the spudger was laying on to the battery when i pryed it.
by
Did u pry on the volume lets side or logic board side?
It's also possible that when unclipping the dock connector a componant was knocked off also.. Can you inspect for damage?
by
Here is a picture of the connector: http://imgur.com/pRqjczv
I have inspected the connector and everything looks fine. Sorry for bad quality picture, I will upload some better ones tomorrow. I pryed the connector up from the volume bar side. Thank you so much for helping.
by
I doesn't seem damaged to me. What do you think con?
by
Here is another picture: http://imgur.com/Cca9HXN
by
Show 7 more comments
Add a comment
Add your answer
Iver will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 477
