7.9 inch display iPad Mini, with 16, 32, or 64 GB of storage.
651 Questions View all
Can I replace A5 chips to A7 chips in iPad mini 1?
I have heard a roomer saying," You can replace chips from an iPad or iPhone. If you dont want to upgrade to a new phone. but simply make it faster."
Is this true?
If so, I want to upgrade/replace an A5 chip in my ipad mini (1st gen) to an A7 chip?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
These aren't plug and play chips---but rather soldered on masterpieces consisting of multiple layers of circuitry embedded in a wafer that stack on each other via an array of miniature solder balls separated from each other by less than a millimeter. One mistake, or a solder ball bridging to the next, and the whole thing doesn't work. There are only a few artists worldwide that are capable of replacing a CPU chip. In the unlikely event that such a switch was theoretically possible, it would surely be less expensive to just get a new device.
Score 5
Comments:
That only works if the pin layout is the same. If you review the chip tear downs its clear they are not the same size or pin assignment compatible.
by
@Dan That only works....never. Of course, never. My answer is addressing the idea of what it would take to replace chips. I believe that there are people in some corners of the world right now that play switcheroo with the big NAND chips from beat up boards and put them on iCloud locked good condition boards. But man. What a job!
by
Guess I wasn't clear, I agree with you! Its just nonsense with the SoC chips.
by
Desperate people will do almost anything. Look at the Lead recovery efforts in China just a few years ago thats still going on. We shipped them the old CRT's and Lead Acid batteries we had. They let their kids break up the stuff and in open pits burn the stuff letting the lead vapors pollute not only the environment but also poison them selves and their children. We saw the same thing in Japan with Mercury poisoning in the early 60's.
by
Add a comment
Sadly no you shouldn't be able to do this due to the difference in programming I to have heard of this rumor but have not encountered any cases myself but usually you can't. Some devices are able to do this but Apple usually changes all the programming between the chips every generation from what I know.
Add a comment
Doubt this is even possible
Add a comment
Add your answer
Tonio Tech will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 105
All Time: 2,871
