Getting no signal since replaced charging dock iPhone 4
I replaced the charger and it now charges but my phone can't get any signal now I've checked the silver plug next to battery plug and its on what can it be ?
Look very closely for pry damage on board from battery removal if time/date are correct
Date and time are incorrect what is the issue now then?
No it keeps going wrong then correct
Connect to wifi then toggle airplane mode on then off and see if that solves
Try this unhook the little cable that is near where the battery connector goes.
iPhone 4 Cellular Antenna Replacement
repeat step 10 and unhook then rehook the cable. make sure it is on tight but dont force it
Is the time and date correct?
Connect the phone to iTunes on the laptop it will change the time and date for you.
Or go to setting then general and time and date and set to auto.. Make sure your connected to wifi
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
