The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
603 Questions View all
How do I make the music stop playing wired through my earphones?
My music keeps playing in a wired way through my earphones i dont know what to do. The music sounds strange while playing only workd when i hold it to a certain angle. My music plays perfeclty when theres No earphones. What do i do??????
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi Kimberly, if you follow the link highlighted that Sophia has provided you, you can purchase a new headphone jack should you find that the one currently installed is damaged in some way preventing optimal performance. If you feel comfortable or know someone that may provide assistance, you can follow the guide here below:
Samsung Galaxy S4 Headphone Jack Assembly Replacement
Many times when a cable is plugged into the device and gets yanked or bend at weird angles normally not suited for how the cable is plugged in the inside can be bent or damaged over time. If you have any further questions please feel free to ask :)
~Gadget~
Score 1
Comments:
Thank you. Is there an easier way to sort this because im 13 and know where to get a new head phone jack and all the supplies needed. So if you know any easier ways please comm
ent. Kimberley
by
Ok, after some research I found out that this is a common occurence with the Samsung Galaxy 4. Many have heard popping and distortion with the headphones especially towards the maximum volume. The solution a lot of people had found, as well as tested on multiple Samsung Galaxy 4 phones, was all that was needed was a firmware update that Samsung had actually fixed due to a software issue. I would suggest doing that first before anything else as many people believed it to be a hardware issue, but just needed a firmware update. Let me know if this solves your problem and I will continue to help you with further guidance.
~Gadget~
by
Add a comment
First, make sure your earphone is ok.
If it's okay, there may be something wrong with your headphone jack.
Have a good luck!
Comments:
If theres something wrong with my headphone jack what do i do
by
Add a comment
Add your answer
kimberley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 150
