Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
Got wet, only backlight doesn't work!
My iPod Touch was dropped in a glass of water well over a year ago. EVERYTHING but the backlight works. Sound, touch screen, syncing, wifi, etc. all work.
Anything I can do? It's way out of warranty because of the time let alone the water indicator.
Score -1
Add a comment
1 Answer
Chosen Solution
The back-light appears to be part of the LCD assembly so the cause is either faulty LCD assy or the power to the back-light is not there due to a poor connection or main board fault.
Try disassembling the device and simply unplugging the LCD connector. You may have a small amount or corrosion on the contacts that can be cleaned off.
Teardown
Display replacement
HIH
iPod Touch 2nd Generation Teardown Image
Guide
iPod Touch 2nd Generation Display Image
Guide
iPod Touch 2nd Generation Display Replacement
Difficulty:
Difficult
35 minutes - 1 hour
1 Comment:
Thanks Richdave... I will try that. Do you know if the Gen 1 and the Gen 2 display are the same? I have a Gen 1 iPod that the display works, but the battery and the wifi don't work. I could frankenstein the good one with the gen 1 parts?
by
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 10,853
