Guides and support for various TV brands and styles.
2509 Questions View all
RCA 50" Rear Projection TV wont come on but has power thru the bulb?
front lights blink when powered on and then go off. Replaced the bulb but same issue. I checked and have power through the bulb but when tv is turned on the bulb will not light up? Any help?
Comments:
what model is your RCA? What sequence does the front light blink?
by
it is a RCA HD50LPW175 and the light sequence is 3 blinks and turns off
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Richard, check for a chassis number on your TV. The Power LED blinks three (3) times. Set restarts automatically after 20-30 seconds. After 3rd cycle unit remains shutdown (unplugging AC resets unit). Probable Cause: 1. Failure of lamp cooling fan or DLP device cooling fan. so check on those and see what you find. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Richard will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 731
