An external optical drive by Apple, essentially a rebranding of the MacBook Air SuperDrive.
35 Questions View all
Can I use the internal drive as a SATA optical drive?
I have a newer Apple USB SuperDrive. I want to take the internal drive out of its casing and use it in another drive enclosure as a SATA optical drive. Can I do this?
Score -1
1 Comment
I think you need to give us some more info on this other case. Is this also a USB case or something else?
by
Add a comment
1 Answer
Chosen Solution
It is a USB case. I did open it and it looks like it may not work. Connections are soldered, I believe, unless there is an adapter I can use.
Add a comment
Add your answer
Carl Shank will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 222
