Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3138 Questions View all
Can I take out the battery while its on?
Hi guys,
I attempted to repair my screen yesterday by removing only the glass but damaged the screen. To test if id broken it i plugged it in and connected my phone to itunes which proved what i thought. Now i have no means of turning it off again.
I have a full screen replacement on the way and was wondering if i can connect the screen to the phone while its on? If not, will removing the battery while its on do any damage to it?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
If the screen is still on the phone and you can use the phone button press home button to light up the screen now press and hold home button and power together as soon as you see the screen turn off take fingers off both buttons. That will be it shut off.
Failing that just unclip the battery with a non static tool or plastic pick an you should be grand have had to do this on many occasion without damaging the iphone
Score 1
Comments:
The screen was completely destroyed, i accidentally cut into it while trying to remove the glass so i dont have a home button on it.
Can i just confirm that youre saying its 100% safe for me to take out the battery while its on?
by
Also, can i connect the new screen tot he phone while its on?
by
Yes you will be grand removing the battery..
It's safer to remove battery than install new screen while it's on
by
Thankyou for your help :)
by
Hello guys, i just deattached battery cord from unresponsive 5S while it was on. I used plastic pick for it. Now the phone wont power up or connect to iTunes when i attached battery... Any ideas how to repair it? I allready tried home button / wake button combo..
by
Add a comment
Yes you can but make sure phone screen is not on like make sure you hit power button first to shut screen off then connect everything except the power ribbon cable make sure that's last then put that one in put screen fully together then it will work guaranteed it I've repaired cou tlesss phones iPads android tablets windows tablets....
Comments:
Lol still chance of blowing backlight circuit just because the battery was plugged in and you plugged or unplugged the screen cables.
by
Add a comment
Add your answer
f7y801 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 97
All Time: 1,223
