1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
143 Questions View all
No output or input devices found?
My late 2010 macbook air sounds stopped working. I go to sound and it says no output device found nor input. I reinstalled the software and it didn't get fixed. I booted Im safe mode and still no sound. Help!!! I also did the command+control+p+r+m and it didnt work nothing works!!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Dropped or liquid spill - shorted port?
As a work around you can use a USB dongle (aka adaptor) which should be identified, as USB. USB audio is separate from digital and analogue audio.
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
If your system profiler doesn't see the speakers, software reinstallation will do nothing for you. Open it up and reconnect the speakers to the logic board. Here's how: MacBook Air 13" Late 2010 Right Speaker Replacement
Score 1
Add a comment
Add your answer
Luis will be eternally grateful.
Past 24 Hours: 24
Past 7 Days: 130
Past 30 Days: 496
All Time: 7,282
