Dell Latitude E5400 Notebook computer is powered by an Intel Core 2 Duo T7250 / 2.0 GHz and features a 14.1in screen with a max resolution of 1280 x 800 ( WXGA )
10 Questions View all
Intermittent Screen flickering when moving lid on Dell Latitude E5420?
Hello,
I have had a problem with my Dell Latitude E5420m were the screen starts to flicker when the lid is moved. This is a intermittent problem as you can find the right position fro the lid and it works fine. I have also plugged in an external monitor to check the graphics card and had no problems. Due to this I believe the problem is the ribbon cable connecting the screen to the board. I have re-seated the ribbon cable attached the screen but I am struggling to find a way to get at it on the board, and didn't want to just start taking screws out at random till I did :)
I will upload a couple of pictures of were I have got up to with disassembling the laptop. If someone could point out the best way to go from here I would be very grateful.
Kind regards,
Chris
Add a comment
1 Answer
It is pretty easy to work on these LCD monitors. It looks like you disassembled the bottom keyboard/motherboard side but we are mostly interested in looking at the top monitor part of the laptop. So I would remove the monitor bezel which exposes everything you need to see to remove and check the lsc panel. Here is a good reference from YouTube: Screen Replacement
Comments:
Hello,
Thank you for your response. I have already removed the screen and tested it and I believe the problem is the ribbon cable from the board to the screen, but it looks a little difficult to get at. If you have any experience with type of thing I would appreciate the help.
by
Add a comment
Add your answer
Christopher Jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 2,845
