Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3189 Questions View all
Where can I get an iPhone 5 logic board component repaired?
I was recently swindled and have an iPhone 5 with a component missing from the logic board. It's required for the front camera/speaker flex connector. I read about "bare" logic boards on ebay for cheap but they require soldering anyway so I figured replacing one component would be cheaper. I just don't know of a shop that can do this.
Add a comment
Chosen Solution
Derek, that is reference designator L39. It is a 90-OHM-50MA TCM0605-1 Common Mode Filters(SMD) for High-speed Differential Signal Line. It is made by the TDK corporation. As for getting it fixed, this will depend on where you are. A good electronics repair shop could do it for you, or you may want to contact user jessabethany on here for more help on the soldering part of your job. Hope this helps, good luck.
Score 1
Thanks oldturkey03! Just knowing which component it is is great. I am in Southern California near Los Angeles (Orange County).
Add a comment
I wouldn't be certain on the part you need to replace or if it's a readily available part but I'm sure there's sum1 with logic board knowledge on here that can help you good luck
Add a comment
Add your answer
Derek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,307
