iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
379 Questions View all
Late 2009 27" iMac White screen at startup after replacing hard drive.
So I have a late 2009 C2D 27" iMac (A1312 EMC 2309)
I just replaced the hard drive. I reassembled it, it powers up, I get the startup chord, and the screen goes full white. No access noises for either HD or internal SuperDrive. I cannot install from the commercial Snow Leopard disk (holding down the C key at boot did nothing)
I checked and found that the mobo end of the thin, 4 conductor flat ribbon cable (Vertical Sync) had gotten munged, so I replaced it, but I have the same symptoms.
Does anyone have any input on this? LVDS cable, maybe?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
This is most likely a hard drive issue. See if you can format and put a system on your drive using another Mac, then put it back in.
Score 1
Add a comment
Hi,
I've just replaced my dead drive and I'm experiencing the same symptoms. Blank startup manager, will not boot from original install media (keeps ejecting it), it will not load in target disk mode... ...if left to it's on devices I get flashing folder and question mark. I'm about to remove the drive to format it and was wondering if this fixed the issue you were experiencing.
Any additional advise is much appreciated!
Add a comment
Add your answer
Karl Isselhardt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 767
