No Service in any location.
Everything on this iPhone works beautifully except the phone. There is a "No Service" message in the upper left hand corner. When you first turn on the iPhone, the upper left hand corner says "Searching" but after a second or two it says "No Service." It can't seem to connect. Any ideas?
Update
Hey Markus. I don't know if it was ever opened in the past. It's opened now. The antenna connectors seem to be intact. I've been told it's either the antenna or the communications board. Definitely not a firmware/software issue. I can get a used comm board on ebay for $48. Might do it. Thanks for your ideas. cousinphil
3 Comments
Have you set up an account with a phone service provider?
by mayer
hi phil,
sure, the antenna could be a problem. the best way would be a second iPhone to interchange the parts - but not everyone has that option.
by markus weiher
Hey, thanks for your input. It turns out that it was a hardware problem. Probably the comm board. Know where I can get one cheap? All the broken iPhones on eBay are going from between $75 and $90. Ouch!
by Phil Norris
