15 inch "Desk Lamp" iMac G4 700MHz M6498 PowerMac 4,2
20 Questions View all
How do I remove the Logic Board from the base?
I need to replace the lower base, but can't seem to locate all the screws that attach the logic board to the base? Any ideas?
Add a comment
1 Answer
Chosen Solution
Make sure that all removable parts of the logic board such as RAM and the airport card are removed. Then, take out all the screws that you see on the logic board.
Hi. Thanks. There were a couple of screws I couldn't locate. There was a plastic screw which I hadn't identified and also some smaller Torx ones near the power socket. All sorted now.
Add a comment
Add your answer
Sean will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 154
