Not Charging, Not Recognized, Replaced Dock Connector.
iPhone was charging only when off.
Not recognized by iTunes [Mac]
Replaced Dock Connector as suggested [Not Battery].
Still after replacement:
• Still Won't Charge from iMacs [3 different devices]
• Tried 2 different wires [one fairly new]
• Still Won't Charge from adapter (used to charge only when "off" before the stopped charging and stayed that way after replacing connector)
• When plugged to 3 different iMacs get same warning: "USB Devices Disabled Unplug the device using too much power to re-enable USB devices.
In brief: No connection or charge improvements after replacing Dock Connector
2 Comments
caduceus, since you already changed the battery and the dock connector, there is a possibility of logic board charging circuitry issues. I would suggest that you try another dock connector. Just in case you have a defective one. If that does not work, you will have the check the charging circuitry. I am sure that you also already tried to place your phone in DFU mode to see if it is being recognized....
by oldturkey03
Thank you very much [Interesting background, Health Care provider myself]. I will consider the second replacement option. Yes, I tried the DFU and it did not work... It looks like I have a real mess in my hands...oh, if only "cracking" would work...
by caduceus
