Fix Your Stuff
Right to Repair
Store
Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3408 Questions View all
Replace battery & Charger Port. Phone wont power on after it dies!
Hey, I am fixing a phone for a client. When I got it the phone would not power on. So I replace the battery.
The powered on fine. So I replaced the charger port as well. The phone powered on and charged fine. I thought it was fixed.
So the next day the phone died. So I went to charge it up. NOW THE PHONE WONT EVEN POWER ON AGAIN! I am stumped. Do you guys have any suggestions as to what the problem could be.
Add a comment
Most Helpful Answer
A new program that started about 10 days ago: Check your serial number here to see if it qualifies for the Battery Replacement Program:
https://ssl.apple.com/support/iphone5-ba...
Score 1
Add a comment
Could be the battery thats faulty or the charge port
Comments:
I replaced the battery and the charger point. It was working until the battery died. Now the phone wont even power when I put it in on the charger. So Now I am back at square one.
by
Add a comment
Same issue here. Phone came in dead. Put in a new battery and it charges fine. However if you let the battery die it will no longer charge. Tried several known good batteries and charger ports. I read that there is a component called the U2 IC. It is a 36 pin chip. When this fails you will get the symptoms we are experiencing. Looks like a pretty advanced repair. Hoping someone else has run across an easier solution.
Add a comment
affter replace charging port
phone dead
Comments:
what go wrong
ant advice
by
Add a comment
what go wrong
any advice
Add a comment
Add your answer
Derek D Hopson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 617
