Water damage to keyboard, computer shut itself off
This is actually for my friend's computer. He accidently spilled some water and the keyboard got quite wet. At some point the computer ended up shutting itself down.
I was wondering what this means? What do you suspect has been damaged?
He hasn't attempted to turn it on and is letting the computer dry out.
I suggested to him that he removed the keyboard when it's dry on the outside so he can see if water has reached, say, the logic board.
Is this good advice?
3 Comments
Here are some updates:
He opened his computer and didn't really find water anywhere. However, he did find what looks like dried up water on this curved copper part located to the left of the fan. (Part of which is in the yellow box in this image: http://s1.guide-images.ifixit.com/igi/1N...)
He also sees some very small white spots on circuits. Perhaps this is mold?
P.S. At this point the logic board hasn't been removed.
by Michael Swenson
here is a picture from above - the part you mentioned is the connector and cable from the keyboard - if this part is shorted - the MacBook won't start (the power button is on the topcase and use this connection)
http://s2.guide-images.ifixit.com/igi/lr...
the whits spots are no mold, it looks a little bit similar, it's oxidation - and oxidation is conductive - you can read this for a little bit more about the oxidation problem
by markus weiher
Okay he opened it and brushed many parts with isopropyl alcohol. He noticed that there was more significant water damage on the RAM than anywhere else.
He attempted to turn it on after putting everything back in place and it does turn on, because the screen does the initial flicker and the LED comes on and stays on, but nothing happens. It does not load OSX or anything.
What could this mean? BTW thank you for all the help so far! I appreciate it very much!
by Michael Swenson
